Hello everybody,
Changelog 23.1.20230911
- Mail: equal sign followed by numbers is mangled in plain-text mails (e.g. =22 becomes a ")
- Calendar: fix at certain times calendar showed Tuesday-Monday instead of Monday-Sunday (depending on timezone)
- Api: Store recoverable password (encrypted) for shares so you don’t have to change it when you forget
- Api: fixed date&time display on mobile devices
- ActiveDirectory: fix regression causing password change to fail with error “no SSL connection”, even if one was used
This update contains “only” bug fixes.
in chronological order.
Many greetings
Your EGroupware team
created
last reply
- 2
- 842
- 1
user
- 1
like
- 3
links
