Hello everybody,
Changelog 23.1.20231110
- Collabora: fix inserting images from filemanager
- Notifications: aggregate messages by app:id to return only latest one, also added a cut-off date of 30 days and cleaning older messages
- Addressbook/REST API: categories were lost, when updating existing contacts
- Mail/REST API: always add signature below supplied body (independent of user preference for reply/forward)
- Calendar/REST API: adding of participants to events
- ActiveDirectory: supporting well-known SIDs not matching the domain-SID e.g. S-1-5-32-544 for BUILDIN\Administrators
- AD Import: run full group import for AD, as it does not update modification time of group, when memberships change
- AD/LDAP Import: allow setting import frequency < 1h eg. .1: every 5min, .5: every 30min
- Api: converted action-system to TypeScript
- Many translations
- New icons (email) WIP
Emails that are generated via the Mail/REST API in EGroupware now always have the signature placed below the delivered body.
This is now independent of the user settings for the signature position.
It is now possible to add participants to appointments created via the Calendar/REST API.
The automatic import of AD/LDAP users/groups can now be set finer and shorter down to 5 minutes.
The value should not be set shorter than absolutely necessary in order not to unnecessarily burden EGroupware and the AD/LDAP systems.
in chronological order.
Many greetings
Your EGroupware team
