Hello everybody,
Changelog 23.1.20240430
- Notifications: fixed deleting and grouping of popup notifications by app-name and -id and show full total independent of max. 100 shown entries
- Notifications: if deleting all (visible) messages, directly return the next junk, to ease cleaning them up
- Notifications: configurable number of days (default 30), after which older notifications get automatic deleted
- Api: Fix list updates while app was hidden were not all shown when switching back to the app
- Api: Fix removing email tag did not properly update display
- Mail: fix forwarding and reply to mail with just a PDF or image was showing it and not opening a compose window
- Mail: fix list of Sieve rules was not scrollable
- Mail: configurable limit to exclude attachments from automatic saving as drafts, default is no limit / attachments are always saved in drafts
- Mail: revert to use first and second part of full rfc822 mail address outside angle brackets as first and last name
- Addressbook/Mail: new value “Hide groups without email” for preference “Hide user groups as distribution list”
- Calendar/CalDAV: do not allow to resurrect a deleted meeting by accepting it again via CalDAV or meeting-request from mail app
- Tracker: Fix mailhandling for a specific queue did not use correct queue ACL
- Tracker: Fix export would fail for certain filter combinations
- Registration: allow to customize confirmation mail
- InfoLog: config to handle status “archive” as unchangeable (or only changeable by an admin)
- eSync: fix for messages with no text body e.g. just a PDF or an image, returns empty body with attachment(s)
- eSync: fix syncing forwarded and replied flags to client incl. push using highestmodseq, if supported by IMAP server
- eSync: only first to address was shown / send to client
- eSync: fix inline forward with attachment(s) and smartForward (e.g. GMail client) was broken
- EPL eSyncPro: fix not working buttons in policy add or edit
- AD/LDAP Import: import could potentially deactivate or delete users if the connection to LDAP server failed
- AD Import: import was not correctly taking into account primaryGroup of users
- EPL: backups in S3 could not be renamed or downloaded via WebDAV (direct download from backup worked)
- EPL/CTI: fix typo incom(m)ing causing custom configuration to not identify incoming calls correctly
- Many translations
Older messages are now automatically deleted.
The retention period can be defined by the admin. The default setting is 30 days:
Previously, attachments were not saved with drafts and automatic saving. This was intended to avoid overloading (the mail server) and prevent disruptions (for the user) when composing.
The automatic saving of larger attachments could become a problem, especially with remote e-mail servers with poor connections and several simultaneous users.
We have now changed the behaviour: Attachments are also saved during automatic saving. The maximum size of the attachments can (and should) be set appropriately.
The default setting is 10MB:
It is now possible with an additional setting to not display certain groups when addressing an e-mail. To do this, you may have to enter email addresses and leave the groups to be hidden empty.
It is now possible for the admin to write the message text and the subject of the invitation emails:
It is now possible to protect InfoLogs with the status “Archived” against changes:
- Many translations
su@egroupware.org.
Every contribution, no matter how small, makes the translations better
in chronological order.
Many greetings
Your EGroupware team
created
last reply
- 2
- 608
- 1
user
- 1
like
- 3
links
