1 / 3
Oct 2024
Hello everybody,
we have released a new maintenance relaease 23.1.20240930.
Release notes:
  • PHP Security Update to 8.3.12
  • All apps: limit number of loaded links to 20 and offering to load more, if more are available
  • All apps: allow longer sharing-path up to 1024 chars (instead of just 255), which also limited Collabora editing
  • Admin: bulk action together with a selected group and select all was not working / complaining about nothing selected
  • Admin: trying to create a global category with a parent gave a validation error
  • Calendar: differ between private events and only having free/busy-rights by showing “busy” instead of “private” as title
  • Mail: remove content of script and style tags from displayed html mail
  • Mail: fix wrong badge (with number of unread mails) when using empty Trash or Spam folder
  • ActiveDirectory: allow to disable VLV controls, if your AD has problems with it AND can return all users in a single query
  • Filemanager: fix not being able to become superuser
  • Kanban: copying of boards did not copy swinlanes
  • All apps: updated translations from our translation server
  • CalDAV/CardDAV: .well-known redirects were always http (deb/rpm update of egroupware-nginx.conf)
  • Mobile: fix not working navigation
  • Many new translations
:warning: This Maintenance update is provided via Docker container.
:uk: Manual (container) update/downgrade in a Docker installation
:de: Manuelles (Container)-Update/Downgrade in einer Docker-Installation
This time only bug fixes and minor changes.
in chronological order.
Many greetings
Your EGroupware team
  • created
    Oct '24
  • last reply
    Oct '24
  • 2
  • 356
  • 1
    user
  • 1
    like
  • 3
    links
pinned globally Oct 1, '24
9 days later
unpinned Oct 11, '24
