Hello everybody,
we have released a new maintenance relaease 23.1.20250113.
Release notes:
- Mail: use account of selected From address to send mails, not the current open mailbox
- Mail: prefer identity email over SMTP username for Return-Path header, if both are from the same domain
- Mail: Layout improvement in the compose window
- Addressbook: fix non-active accounts where visible for non-admins, if hidden accounts exist
- All apps: merge-print of OpenDocument files now also replaces in header- and footer-lines or text-frames (styles.xml part of the document)
- Tracker: Add âView linked Time Sheet entriesâ action
- Invoices (EPL): allow to use Invoices app as viewer for e-invoices in Mail (without rights for Invoices app itself)
- Invoices (EPL): allow to select a mail template and directly mail invoice to buyer
- Invoices (EPL): attach imported invoice pdf/xml to the imported invoice and link it with the seller
- Invoices (EPL): allow to set and import product characteristics and country of origin
- Invoices (EPL): display/import invoices in UBL XML syntax too (generated invoices use CII syntax)
- Invoices (EPL): allow to download multiple invoices as PDF, XML or ZIP-archive
- Invoices (EPL): allow to select âXML invoiceâ, even if Collabora is available, e.g. for customers requesting XML over PDF
- Invoices (EPL): additonally support UBL syntax for import or display, beside the already used CII syntax, used for creating invoices
- Many translations
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20241214âŠ23.1.202501133
We also provide a new package egroupware-docker for upgrading PHP Swoole. This is not directly related to the EGroupware update, but should still be installed.
We have moved the setting for HTML/text messages to the top.
Adding additional fields is now possible via a drop-down list on the left.
It is now possible to place/fill placeholders in documents in the header, footer and text fields.
It is now possible to call up the timesheets belonging to an InfoLog via the context menu.
We have added some new functions and improvements to the Invoices applications.
- Many translations
su@egroupware.org.
Every contribution, no matter how small, makes the translations better
in chronological order.
Many greetings
Your EGroupware team
created
last reply
- 2
- 307
- 1
user
- 1
like
- 4
links
