Hello everyone,
we have released a new SECURITY and Maintenance Release 23.1.20260108.
Release notes:
- SECURITY and Maintenance Release: strong recommendation to update to this release (or 26.0.20260108) immediately
- Many thanks to Łukasz Rybak who found and reported the vulnerability (CVE-2026-22243)
- Addressbook: Hide group distribution list from email search results when group has an email & hiding groups without email address
- Addressbook/CardDAV/REST: fix not working search for phone-numbers (you need at least 9 digits!)
- Invoices: allow setting or importing non-integer position identifier (BT-126) e.g. 1.1, 1.2, 1.3, 2.1 instead of 1, 2, 3, 4
- Many translations
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20251119…23.1.20260108
This time only (security) fixes.
Please make sure that this update is installed!
The version used can be found at: Admin/Admin/Changelog and versions/Changelog
https://help.egroupware.org/t/new-features-preferences-or-other-important-things-since-release-of-egroupware-23-1/77410
in chronological order.
Kind regards
Your EGroupware team
