1 / 4
Jul 2021
I am trying to install egroupware on my windows 10 but the requirements fail me.
No dependencies are installed: you need to run “cd C:\xampp\htdocs\egroupware2” AND either “./install-cli.php install” OR “composer install”!
I do not know what I should do, I am a little new in this world
I appreciate all the possible help.
  • created
    Jul '21
  • last reply
    Aug '21
  • 3
  • 1.3k
  • 2
  • 2
    links
Already get fix it.Thanks.
Since 2007 I have had the application in windows with xampp / wamp and now we are simply updating the application at the same time we change the version of windows server ( 2008 to 2019).
In windows 10 some performance / configuration tests were simply performed
17 days later
Hi Mike.
You just have to bear in mind that there are some developments that you don’t become in your installation. Especially the use of a push server to achieve the function of push messages. Most updates in the EGroupware interface are now realised via this.
However, this requires a standard EGroupware installation based on Docker.
Unfortunately, you did not reveal how you solved your problem.
Since your problem is solved, please mark this topic as solved:
