Hello everybody,
we have released a new maintenance relaease 23.1.20241128.
Release notes:
- PHP: security update to 8.3.14
- All apps: many fixes in Fancy theme and new Bootstrap icons (see 23.1.20241111 pre-release)
- Tracker: desktop version uses now a nextmatch list for comments
- Calendar: new preference for changing resource status when event is moved
- Calendar: when opening calendar as InfoLog, event participants (user accounts) are copied to InfoLog responsible
- Projectmanager: Add a config setting to choose which project statuses we include for link search
- Mail: if Sieve editheader extension is available forward with a From header matching the recipient to avoid SPF and DKIM problems/misalignment (need to be enabled in Dovecot)
- Many new translations
plus topics from pre-relaese 23.1.20241111
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20241008…23.1.20241128
We have upgraded the included PHP from version 8.3.13 to version 8.3.14.
This is a security update: https://www.php.net/releases/8_3_14.php
We now present the comments in a list:
The status of postponed appointments can now be controlled:
When creating an InfoLog from an appointment, the participants (users in the EGroupware) are now entered as task responsibles.
We have added a configuration to choose which project statuses we include for link search
When forwarding emails via Sieve to (external) recipients, SPF and DKIM entries may cause problems. Some providers refuse to forward emails.
If the editheader extension is installed and configured on the mail server (Dovecot), the forwarded email can be “corrected”.
su@egroupware.org.
Every contribution, no matter how small, makes the translations better
in chronological order.
Many greetings
Your EGroupware team
