Sto provando ad installare eGw 19 su Cento 7. Ho seguito tutta la procedura e sembra andare a termine correttamente. Non riesco però ad entrare in eGw perché mi appare l’errore 503 su Apache.
Eseguendo:
docker-compose logs -f --tail=10
Attaching to egroupware-watchtower, egroupware, egroupware-db
egroupware | password: VG-|RQ9zgI|D<Hsd
egroupware | You can log into EGroupware by pointing your browser to http://localhost/egroupware/
egroupware | Please replace localhost with the appropriate hostname, if you connect remote.
egroupware | * Starting periodic command scheduler cron
egroupware | …done.
egroupware | [12-Jan-2021 10:59:07] NOTICE: fpm is running, pid 1
egroupware | [12-Jan-2021 10:59:07] NOTICE: ready to handle connections
egroupware | [12-Jan-2021 10:59:07] NOTICE: systemd monitor interval set to 10000ms
egroupware-watchtower | time=“2021-01-12T10:50:33Z” level=info msg="Starting Watchtower and scheduling first run: 2021-01-13 04:00:00 +0000 UTC"
egroupware-db | 2021-01-12 10:47:40 0 [Note] Server socket created on IP: ‘::’.
egroupware-db | 2021-01-12 10:47:40 0 [Warning] ‘proxies_priv’ entry ‘@% root@84b1f68e808c’ ignored in --skip-name-resolve mode.
egroupware-db | 2021-01-12 10:47:45 0 [Note] InnoDB: Buffer pool(s) load completed at 210112 10:47:45
egroupware-db | 2021-01-12 10:47:45 0 [Note] Reading of all Master_info entries succeeded
egroupware-db | 2021-01-12 10:47:45 0 [Note] Added new Master_info ‘’ to hash table
egroupware-db | 2021-01-12 10:47:45 0 [Note] mysqld: ready for connections.
egroupware-db | Version: ‘10.4.17-MariaDB-1:10.4.17+maria~focal’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
egroupware-db | 2021-01-12 10:52:00 8 [Warning] Access denied for user ‘egroupware’@‘172.18.0.3’ (using password: YES)
egroupware-db | 2021-01-12 10:52:01 9 [Warning] Access denied for user ‘egroupware’@‘172.18.0.3’ (using password: YES)
egroupware-db | 2021-01-12 10:52:01 10 [Warning] Access denied for user ‘egroupware’@‘172.18.0.3’ (using password: YES)
Qualche idea?
created
last reply
- 5
- 1.6k
- 2
- 5
links
