1 / 2
May 2024
Hi All,
I was wondering if it is possible to create series entries in infolog from a multiple selection of emails.
I would like to register incoming emails for a project by selecting them in order to create a series of entries in infolog.
Is this possible in any way ?
Thank you
Gabriele
  • created
    May '24
  • last reply
    May '24
  • 1
    reply
  • 366
  • 2
  • 1
    link
Hi Gabriele,
converting an email into an InfoLog entry is currently an interactive operation and therefore grayed out, if you select more then on email in the mail app’s context menu.
Only way that could work would be either:
  • opening many popups for each selected email or
  • not opening the popup but directly saving the InfoLog entry
None of the above is currently implemented.
First option is probably not a good idea anyway, but the second one could be implemented. If you are interested in sponsoring that feature via a couple of hours of support-budget1, please get into contact with our office.
