Hello there,
I am working on customizing our EGroupware environment to better suit our teams needs; but I have hit a roadblock when it comes to creating and deploying custom templates for specific modules.
We primarily use EGroupware for project management, task tracking, and file sharing. While the default templates work well, we would like to implement custom templates for
Including additional fields to capture specific project metrics and KPIs. With a more tailored structure for prioritization and progress tracking. Customizing the layout to match our internal reporting standards.
I have looked through the documentation and tried exploring the Admin Panel; but I am unsure about the best approach to.
Design the templates Do I need to modify any files directly; or is there a built-in editor? Deploy these templates without affecting the default setup for other users who do not require customization. Ensure compatibility with updates to avoid breaking functionality during future upgrades.
Also, I have gone through this post; http://help.egroupware.org/t/best-practice-of-creating-a-custom-table-in-egroupware-machine-learning which definitely helped me out a lot
Thanks in advance for your help and assistance.
created
last reply
- 1
reply
- 170
- 2
- 5
links
