Hi Giovanni,
Hmm, that should not be possible, CreateObject will either throw an exception or return the instantiated class, it can not return NULL. You must miss something …
CreateObject('etemplate.etemplate') instantiate to old eTemplate class from the deprecated, and by default NOT installed etemplate app. You either have to install it and it dependency the old API (phpgwapi), or migrate to new Api\Etemplate class, which is mostly compatible.
I have no idea about that function, not aware it’s provided by either the old nor our current API.
Searching for it, I found only one reference to it’s name in the old translation-tools:
So it probably existed at some point in time, but not anymore.
