1 / 14
Nov 2017
Hello,
my egroupware community version runs on linux centos 7 and postgres database 9.6 … everything works ok except infolog. let me know the next announcement :slight_smile:
Database error
Invalid SQL: SELECT main.info_id FROM egw_infolog main LEFT JOIN egw_infolog_users ON main.info_id=egw_infolog_users.info_id AND egw_infolog_users.info_res_deleted IS NULL LEFT JOIN egw_infolog_users attendees ON main.info_id=attendees.info_id AND attendees.info_res_deleted IS NULL WHERE ( (info_owner=5 OR (egw_infolog_users.account_id IN (-2,-1,5) AND egw_infolog_users.info_res_deleted IS NULL) OR info_owner=5 OR (info_access=‘public’ AND info_owner=5)) AND NOT (info_status IN (‘deleted’,‘template’,‘nonactive’,‘archive’)) ) GROUP BY main.info_id
ERROR: operator does not exist: character varying = integer
LINE 1: … ( (info_owner=5 OR (egw_infolog_users.account_id IN (-2,-1,…
HINT: No operator matches the given name and argument type(s). You might need to add explicit type casts. (-1)
best regards
Evgen vodopivec
Hi Evgen,
we have not done any testing with PostgreSQL so far :frowning:
Looks like PostgreSQL needs an explicit cast there.
I will look into it and let you know when it’s fixed.
Ralf,
Is this file included when I do a fresh install using “git”?
If yes, then there is still at least an issue when creating a new todo-item:
Database error
Invalid SQL: SELECT *,ARRAY_TO_STRING(ARRAY_AGG(account_id), ‘,’) AS info_responsible,ARRAY_TO_STRING(ARRAY_AGG(info_res_attendee), ‘,’) AS info_cc,egw_infolog.info_id AS info_id FROM egw_infolog LEFT JOIN egw_infolog_users ON egw_infolog.info_id=egw_infolog_users.info_id AND egw_infolog_users.info_res_deleted IS NULL WHERE egw_infolog.info_id=1 GROUP BY egw_infolog.info_id
ERROR: column “egw_infolog_users.info_res_id” must appear in the GROUP BY clause or be used in an aggregate function
LINE 1: SELECT *,ARRAY_TO_STRING(ARRAY_AGG(account_id), ‘,’) AS info…
Yes, it is included when you do a new git install or pull the latest changes.
I believe you found a new issue. I will have a look and report back, when I have a fix (maybe later today).
Thank you.
I will upgrade the install when you want me to test a new version.
Where do you prefer me to report my findings? In this thread? Or create new ones?
Joost
Ralf, this is fixed now. I can create infolog items (TODO) without any error showing.
Thank you
Hello! After reinstalling the latest update, I still report the following error:
<img src="/uploads/default/original/2X/d/d4d325699799c4f346f50ab1dcb128ae84bb6647.png" alt="Slika v vrstici 1" width="561" height="126">
Best regards
Evgen Vodopivec
Hello
I apologize for the speedy mail sent by the previous mail.
After the last installation and repair I received from you, the thing works.
Thank you very much for your cooperation and help
Best regards
Evgen Vodopivec
Hello Evgen,
if an answer solves your problem or if you tell us the answer in your own post, please mark the answer as solution. I have described how to do this:
This helps me and everyone else to keep track of things. Thank you.
You can delete posts.
The mail will only be sent after 10 minutes by e-mail to the mailing list participants, until then you have time to change or delete.
And please note: 1 problem = 1 thread
Greetings
