Hello @RalfBecker,
I hope my message finds you all well and you are all staying at home as requested…
I am trying to use the “options-selectcols” Nextmatch option. According to the documentation I should be able to change the title of some columns and also be able to hide some columns the column selection:
‘options-selectcols’ => // I array with name/label pairs for the column-selection, this gets autodetected by default. A name => false suppresses a column completly.
But it seems that setting this option actually has no result at all… I searched the string ‘options-selectcols’ in the ‘api’-folder and found that it is only used in the documentation I cited above. Was it removed intentionally? Setting adjusted column titles in the column selection would be very nice for me.
Thanks for your feedback and stay safe
Best regards
Alex
