Hello everybody,
Changelog 21.1.20230210
- LDAP: fix LDAP protocol error creating new groups without a description
- Rocketchat: fix realtime api not working because of CSP error
- PostgreSQL: fixed PHP 8.1 problems (affected rows always returning false, not allowing to update entries)
- All apps: several PHP 8.1 fixes
- full list of fixes check: 21.1.20221202…21.1.202302106
- No new functions, only bugfixes
Diff: 21.1.20221202…21.1.202302106
in chronological order.
Many greetings
Your EGroupware team
created
last reply
- 2
- 922
- 1
user
- 1
like
- 4
links
