1 / 3
Jun 2024
Hello everybody,
we have released a new maintenance and security release.
:warning: We do not publish security updates for version 21.1 and before!
If you are not running EGroupware version 23.1, you should (finally) upgrade to 23.1!
Changelog:
  • Mail: fix broken PDF attachments which were quoted-printable encoded
  • Mail: do not stall (quick-)preview on mails without text-part e.g. PDF only
  • Mail: allow to edit/fix mail account if no session password is available e.g. SAML or OpenID Connect SSO login
  • Filemanager: automatic shorten too long filenames and replace 4-byte utf-8 characters, which gave an error when trying to store VFS
  • Calendar: fix editing recurring events of type RDATE/explicit dates
  • Calendar: fix generating/importing exceptions on recurring events using explicit RDATEs instead of a RRULE
  • CalDAV/CardDAV/REST API: fix not working limited result
  • eSync: fix whole-day events were one day longer (shifted by timezone difference)
  • eSync/Mail/Calendar: limit request for all mail and events to 1 year back, instead of previous 178 or 100 days
  • eSyncPro/EPL: fix provisioning loop cause by wrong timezone conversation
  • Calendar/eSync/EPL: better cope with Android bug reporting always 1st of current month as cutoffdate, if a policy is given: use setting of default policy instead
  • Resources: fix category-name not shown in edit, if user has no edit rights to the resources
  • Resources: fix editing on mobile devices gave a template error
  • ProjectManager: if sorting element-list by start, end, budget, time or quantity: consider both varieties, but prefer the requested one
  • InfoLog: now fully supported by REST API
  • Many translations
This maintenance update does not yet contain the changes that we announced in the newsletter:
:uk: Newsletter: Simplified customizing, data security & S3, events
:de: Newsletter: Vereinfachtes Customizing, Datensicherheit & S3, Veranstaltungen
This maintenance update had to be brought forward in order to deliver security-relevant fixes.
:warning: This Maintenance update is provided via Docker container.
:uk: Manual (container) update/downgrade in a Docker installation
:de: Manuelles (Container)-Update/Downgrade in einer Docker-Installation
We have finalised the REST API for InfoLog:
  • Many translations
su@egroupware.org.
Every contribution, no matter how small, makes the translations better :slight_smile:
in chronological order.
Many greetings
Your EGroupware team
  • created
    Jun '24
  • last reply
    Sep '24
  • 2
  • 2.2k
  • 1
    user
  • 1
    like
  • 6
    links
pinned globally Jun 24, '24
3 months later
unpinned Sep 10, '24
