Hello everybody,
- Mail: New option “Name and domain” to show e.g. “John Smith (example.org)” set under “Information to show on email tag”
- Mail: fix diverse problems of rich-text editor, if small paragraphs are used
- Mail REST Api: added reply to an uploaded eml file (with optional preset body and attachments)
- REST Api: allow to create new fields with PATCH for application/json content-type and error on not existing custom fields
- Adressbook/Calendar/REST: fix not parsed custom fields
- Addressbook: Fix distribution list rename
- Api: Fix favorites button in nextmatch header did not work
- Calendar/CalDAV: new calendar-config to allow party-crashers with email matching a given regular expression
- Calendar: update holidays with new thunderbird.net URLs/data for a lot more countries
- Filemanager: fix not working setting “No Access” permission on directories e.g. to hide (unwanted) group-directories
- OpenIDConnect: allow to show as button on login page to use together with regular password login
- Importexport: Fix import through dialog fails
- Tracker: Fix missing assigned users with some access / group configurations
- ActiveDirectory: optionally also use/import groups of type distribution-list
- EPL S3: fix not working upload of backups
- Many translations
It is now optionally possible to display (name and organisation) in the mail client:
New functions extend the options for triggering actions in EGroupware via API.
Documentation (WIP):
https://github.com/EGroupware/egroupware/tree/master/doc/REST-CalDAV-CardDAV#rest-api-using-egroupware-caldavcarddav-server-with-json
Explanation in the picture …
We now use an updated source for the general calendars:
https://www.thunderbird.net/en-US/calendar/holidays/
in
Since version 23.1.20231201 it is possible to authenticate EGroupware against an OpenID Connect (OIC IdP).
It is now also possible to place a button for a selection on the login page:
In setup:
On login page:
It is now also possible to import groups of the type “distribution-list” when importing from AD.
su@egroupware.org.
Every contribution, no matter how small, makes the translations better
in chronological order.
Many greetings
Your EGroupware team
