1 / 3
Jun 2020
Hello everybody,
Changelog 19.1.20200605
  • Calendar/CalDAV: videoconference was lost, if meeting was accepted of updated via CalDAV
  • Preferences: fix delete personal category required admin permission
  • Calendar: do not show Infolog list (Open ToDo’s) if user has no access to Infolog, or no Infolog types selected for display
  • Api: can now select no color with color widget
  • ActiveDirectory: consider security local groups as groups too
  • API: new data-minimizing account display options “Firstname Inital” and “Firstname [ID]”
  • Registration: allow to choose email as user-name and let user choose a primary group from a selection
  • Status app: add group preference as shown users and some performance improvements
  • Tracker: skip loading the default mail account during mail handling, avoids mailhandling failure in some cases
  • Mail: fixed forward as attachment from viewing mail in popup
  • Docker: EGW_MEMORY_LIMIT environment variable to set a higher memory_limit in php.ini (default is 128M)
  • Filemanager: Add a ‘None’ option for editor mime type exclusion so u can override the default.
  • Calendar: Fix bug preventing yearly planner from loading
  • Mobile: Fix sidebar toggle menu in mobile them
  • Setup: Fix backups to keep of 0 gave an error “must be integer”
  • Calendar: Fix missing color when hovering over all day non-blocking space
  • Adress book: Fix Entry in private adress book: no context menu/no open
  • Updated translations
  • Update some icons => svg
:warning: This Maintanace update is provided via Docker container!
It is now possible to remove an existing color selection:
It is now possible to limit the display of users in the status bar via groups.
Further users can still be added:
The PHP parameter memory_limit can now be passed into the docker container.
This allows e.g. to download even very large email attachments.
EGroupware can allow users to register themselves (i.e. create as users). In this dialog it is now possible to choose an e-mail address as user name. Also a group can be selected as primary group.
By default, PDFs are excluded from being opened by Collabora Online. PDFs are therefore displayed by the Web browser or a locally installed PDF reader.
You can now remove this default setting by choosing None in the settings.
The toggle menu in the mobile view should now be available again in all applications and preferably on all mobile devices.
:warning: If this is not available on a mobile device, please post here in the forum, specifying the device, operating system (state) and browser!
In the calendar, the area for creating an all-day, non-blocking appointment is now highlighted in color.
grafik
This update also contains updated translations in different languages. Many thanks to our translators from the community! Great job!
We have again replaced some icons with new svg graphics.
in chronological order.
Many greetings
Your EGroupware team
  • created
    Jun '20
  • last reply
    Jul '20
  • 2
  • 1.2k
  • 1
    user
  • 5
    links
pinned globally Jun 8, '20
1 month later
unpinned Jul 11, '20
