1 / 18
May 2024
Hallo, ich bekomme folgenden Fehler beim Öffnen des Edit-Dialoges einer Resource auf dem Smartphone angezeigt.
Loading eTemplate from /egroupware/api/etemplate.php/resources/templates/mobile/edit.xet?1714462127 failed!
TypeError: Cannot read properties of undefined (reading ‘childNodes’)
at et2_container.loadFromXML (http://xxx.xxx.xxx.xxx/egroupware/chunks/etemplate2-8dc11184.js:7274:31)
at etemplate2$1._load (http://xxx.xxx.xxx.xxx/egroupware/chunks/etemplate2-8dc11184.js:122940:33)
at etemplate2$1. (http://xxx.xxx.xxx.xxx/egroupware/chunks/etemplate2-8dc11184.js:123071:17)
at http://xxx.xxx.xxx.xxx/egroupware/chunks/etemplate2-8dc11184.js:24353:17
Alle anderen Edit Dialoge funktionieren.
EGroupware Version 23.1.20240430
Vielleicht ist es ja ein allgemeines Problem was auch andere haben.
Grüße aus dem Harz
  • created
    May '24
  • last reply
    May '24
  • 17
  • 957
  • 4
  • 4
    likes
  • 6
    links
Die Meldung unterscheidet sich einwenig, ich weiß nicht, sind das Zeilenangaben nach den Doppelpunkten?
Ich habe ein Android 13 Smartphone mit Chrome als Browser.
Christian
hi have the same problem after upgrade to the last version, but no from mobile ( is not intersting for me) but from pc
thanks
thanks ralf, I downloaded the file from github and overwrote the one on the server in the resources/templates/mobile folder but the problem persists :roll_eyes:
Then you did something wrong :wink:
Either you did NOT overwrite it, or you have not reloaded the brower (main-)window, which caches templates.
you were right, I had probably uploaded a corrupt file, now I see it at the correct size, I also compared the two files with Winmerge and they are correctly different, but the problem remains.
I cleared cache and also opened in incognito mode on Chrome but nothing…
Thank you
I made another clean attempt to understand where the problem lies or rather in which version:
  • clean install version 20.1.2020.12.02 - everything ok
  • migration to version 21.1.20221202 - everything ok
  • migration to version 23.1.20230412 - problem
What installation-type is that? Depending on that you have to update the file in the correct location.
In a container Install the fix needs to be applied inside the container in /usr/share/egroupware-sources AND the container needs to be restarted, then the fix works, as you can see e.g. in our demo.
in this installation, I used cloudpanel which uses nginx and mariadb 10.6 like the docker installation… but it’s probably missing something, it would have been perfect to understand it
I preferred this installation, so on the same server I could install various websites that I have in production, which I wanted to migrate to this new server.
EGroupware’s default installation also allows that, as it only creates a single vhost under /etc/nginx/sites-enabled/ and you can add more with different names.
the mystery remains why it gives me that highlighted error, I also tried to install the first version of 23.1 and it gives me the same error… and it drives me crazy… because I preferred to install everything there on a single server, instead of having just one server dedicated to egroupware
No mystery here, I already wrote you the bug is fixed.
