1 / 3
Apr 2023
Hello everybody,
Changelog 23.1.20230412
  • Docker images are available now for architektures: amd64 (as before), arm/v7, arm64/v8 and ppc64le
  • Mail: Make list refresh option available in 3pane-view through column selector
  • Mail: allow placeholders in compose instead of email-addresses to be able to create mail templates
  • Mail/Calendar: show scrollbar, if meeting request does not fit into preview area
  • Filemanager: fix broken expose view for filename click&open action
  • Filemanager: fix after opening and closing the gallery in filemanager the list is no longer accessible
  • Calendar/CalDAV: set current user as owner for events created in resource calendar
  • Rocketchat: fix rocketchat’s status sometimes is not showing up in Status app for bigger installations
  • Status: add new config setting in order to be able to open BigBlueButton calls in separate window with no iframe
  • Status: fix top header (invite button, end call button, …) in call dialogs no longer is visible
  • Status: fix ringing tone never ends after a call being answered
  • Status: fix somehow not found user in contacts stalls whole display of status column
  • Projectmanager: fix missing application and status icon in element list
  • LDAP/AD: if only users get imported, set their primary group and memberships as configured for auto-created accounts (Default group by default)
  • LDAP/AD/Setup: periodic import disables (add|edit)account hooks, if account-repository is not SQL and further performance improvements
  • LDAP/ADS: fix memberships of local groups were lost in periodic account-import
  • EPL/CTI/Addressbook: phone numbers written with unusual separator like pipe symbol where not found
  • full list of changes https://github.com/EGroupware/egroupware/compare/23.1.20230328…23.1.202304122
:warning: This Maintenance update is provided via Docker container.
:uk: Manual (container) update/downgrade in a Docker installation
:de: Manuelles (Container)-Update/Downgrade in einer Docker-Installation
The EGroupware container with the EGroupware source and PHP is now also available for
  • linux/arm/v7
  • linux/arm64
  • linux/ppc64le
https://hub.docker.com/r/egroupware/egroupware/tags2
Please note: These container images alone are not sufficient for a running EGroupware. These container images are intended for integrators who know how to use them.
The new architectures are to be regarded as expirimental. We are happy to receive feedback.
The use on a RasPI is not recommended. It will not be fast enough to work with it satisfactorily.
It is now possible to use placeholders for the email address in email templates:
For appointments created in a resource calendar, the current user is now used as the owner.
It is now possible to make BBB open in new windows.
This is necessary in some environments or for some BBB servers.
Diff: 23.1.20230328…23.1.202304122
in chronological order.
Many greetings
Your EGroupware team
  • created
    Apr '23
  • last reply
    May '23
  • 2
  • 671
  • 1
    user
  • 1
    like
  • 5
    links
pinned globally Apr 12, '23
20 days later
unpinned May 3, '23
