Hello everybody,
Changelog 23.1.20230503
- CalDAV/InfoLog: fix infinit loop causing high database load, if sync-collection report did not query calendar-data
- CalDAV/Calendar: fix recurring events with users only added to an exception and have been deleted or rejected after
- CardDAV/Addressbook: show and allow to sync for default and forced preferences all ABs of the admin user
- Calendar: fix not displayed events of resources when a resource category was selected
- Mail: fix resize of compose window in plain-text mode to display everything
- Mail: fix showing of calendar invitations in s/mime
- Rocketchat: fix rocketchat’s status sometimes is not showing up in Status app for bigger installations
- Status: fix top header (invite button, end call button, …) in call dialogs no longer is visible
- Status: fix ringing tone never ends after a call being answered
- Status: fix somehow not found user in contacts stalls whole display of status column
- ProjectManager: fix display of icons in project- and element-list
- EPL/ProjectManager: fix moving tasks and projects
- EPL/Firewall: fix test gave an “Illegal offset type” error
- EPL/Tracker: fix reports not being displayed and giving errors
- AD/LDAP/Import: for AD always do a full import of groups, as AD seems not to update the modification date, if only members change
- All apps: various fixes in the new web-component based widgets
- Full list of changes 23.1.20230412…23.1.202304283
- fix some critical errors/regressions in the not published 23.1.20230428 release
- InfoLog: can not set project (caused double submit, stalled saving by redirecting to list)
- Calendar: Allow to select multiple categories in sidemenu
- Calendar: Put email address after user or contact
- ProjectManager: fix entries opened in elements list have wrong project linked (after project is changed)
- full list of changes 23.1.20230428…23.1.202305031
As an admin, it is now possible to force or preassign the synchronisation of certain address books.
During the AD import, all groups are now always imported, as it is not possible to determine whether a group has changed.
It is now (again) possible to select several categories in the page menu (hold Ctrl).
Diff: 23.1.20230328…23.1.202304123
Diff: 23.1.20230412…23.1.202305031
in chronological order.
Many greetings
Your EGroupware team
created
last reply
- 2
- 679
- 1
user
- 1
like
- 5
links
