Hello everybody,
- LDAP: fix error creating a new group without a description
- LDAP/ADS: fix periodic import was not converting numeric ID of primary group, in case it is different in SQL
- LDAP/ADS: periodic import calls addaccount hook for existing account when email was just set, to activate mail account
- Account Import: if deleting or deactivating of deleted accounts is configured, run first import as a non-incremental one to do so
- ActiveDirectory: fix import was not detecting members removed from groups
- Calendar/eSync: fix events created on the device are added to the server in a wrong timezone / shifted by some hours
- Mail: display messages containing just a PDF (and no body part)
- Notifications/Async service: fix caching in mail account always used sender from first notification
- ImportExport: fix not working scheduled import caused by failure to update (the not existing) UI
- ImportExport: fix not working import from http(s)
- REST API: fix PATCHing of custom-fields
- REST API: new links collection allowing to link application entries with each other or attach files
- REST API: also log requests with Content-Type âapplication/jsonâ not just âtext/*â
- REST API/Mail: respect user preference to compose in HTML and convert plain body from REST Api call to HTML (bodyHtml attribute forces HTML)
- REST API/Timesheet: new REST API to query, update and delete timesheets https://github.com/EGroupware/egroupware/blob/master/doc/REST-CalDAV-CardDAV/Timesheet.md
- API: show âMy Accountâ in avatar menu on top right, if user has rights to change his contact data
- API: no more session based cache for account list or searches for SQL backend (only for LDAP or AD)
- Registration: Fix contact fields did not get copied to user account
- Admin: fix user timezone not taken into account when displaying admin queue
- EPL: add S3 check to FSCK to delete files not in egw_sqlfs table or empty files from S3 buckets
- EPL: fix finally deleting files from S3 gave an error leaving the files in S3, s3check.php script to check and fix that
- EPL: fix purging old versions also deletes them in S3, if used
- Many translations
We have extended the REST API for timesheets:
It is now possible for users to access their contact details (in the address book entry) directly via a menu item in the avatar menu:
However, this is only a shorter way. Previously, the same was possible via the address book.
The menu entry only becomes visible if users also have the right to edit certain fields:
su@egroupware.org.
Every contribution, no matter how small, makes the translations better
in chronological order.
Many greetings
Your EGroupware team
